black sticky liquid?? | on ElectriciansForums
Discuss black sticky liquid?? in the UK Electrical Forum area at ElectriciansForums.net
shotton, flintshire
Hi
while testing a DB in a primary school today, i found all the conductors within the DB coated in a black sticky, tar-like goo. see attached photos. im assuming its the conductors overheating and the insulation melting. can anyone confirm this. If that is the case, i can't understand it. there are no significant heat sources nearby apart from a stage lighting DB below, which i switched on with all the spotlights on full and left it all day to see if it produced any heat, which it didnt.
any help would be greatly appreciated.
cheers guys
[ElectriciansForums.net] black sticky liquid??[ElectriciansForums.net] black sticky liquid??
Something may have gone bang at sometime or other in the past within the enclosure. I have seen it before, as long as everything tests out OK, and there is no obvious damage, then i would isolate it, and give it all a good clean with solvent cleaner, then have another look.
Cheers........Howard
What's above the DB? I saw one in avery similar state a few years back which was also in a primary school oddly enough. To cut a long tale short after the intitial worry, some questions, a look above the ceiling and some more questions, it turned out that the roofers had spilt a tin of felt sealant over the board from above. It had been isolated and cleaned up to about the state that looks. ie not very well.
theres nothing above, just an empty roof void. but something may have gone bang. i say this because all of the MCBs and RCBOs are the same except one, which is a new one. The IR readings were quite low. of the 9 circuits, 4 were >200M, 2 were between 2 and 4M, one was 1.15M and the last 2 were about 0.96M.
Just a thought, i had something similar a while back, but this was more a greeny black goo.
I found out that the installation had lost it's neutral so all power was flowing to earth and the earth wires were overheating causing the PVC to have some sort of reaction.
So no black stuff before they enter board?
Not a lot of black stuff on the board, just on all of the cables in it.
Not got a clue what it could be. I'm gonna have a pint of the blackstuff and hopefully get educated on this one.
Reply to black sticky liquid?? in the UK Electrical Forum area at ElectriciansForums.net
