Blown LED lamp, who pays? | Page 2 | on ElectriciansForums
Discuss Blown LED lamp, who pays? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Afternoon all...
I have just had a customer ring up and ask me to change his LED lamp. I fitted then in June 2014 so it is just outside the warranty that I offer of 1 year. However, these are LED lamps and you expect them to last longer than a year, this is one of the reasons why the customer chose them.
My dilema is what to charge him?
I have said that I will take the lamp and send back for a refund (so no charge) but I will have to charge him a little just to cover time/diesel etc. Does this seem reasonably?
I realise LED's are supposed to last much longer and I'm sure they do in general, but if they do blow after a year or 2 I cant really see that we can be expected to replace the light bulb for free?
ps.. whats with the odd links that automatically get put in... i.e LED lamp automatically links to a tiltable Piano lamp in Germany!! Thats helpful :confused:
Ive had that same problem, i NEVER fit all in one sealed units, fire rated downlight and LED GU10 only way to go now
offer a years free warranty to change any failures then after that tell them the wholesaler and part no. And they can do it thereself, or pay you for the labour costs
A purpose designed led fitting is always going to be better than something which has been adapted to fit in to a design originally intended to be an incandescent lamp
Buy cheap, buy twice
If you get a good quality led fitting then you'll have no problems
Not necessarily, though I do generally agree with the buy cheap but twice saying.
I currently have a customer that has two failed Halers in her ceiling, approx 2 years old. And I also have several customers with fire rated fittings and Lap LED lamps in them, which have been fitted for 2 years with a very low failure rate, and very simple to repair.
Personally I do not like the sealed units.
How is a sealed unit inherently better?? It's a simple light fitting at the end of the day. This is not rocket science!
I currently have a customer that has two failed Halers in her ceiling, approx 2 years old. And I also have several customers with fire rated fittings and Lap LED lamps in them, which have been fitted for 2 years with a very low failure rate.
I never said a sealed unit is better, but obviously if it's in a damp environment or similar then being sealed will be a good thing.
But a purpose designed LED fitting will always be more efficient and give a better performance than anything adapted in to something designed to be an incandescent lamp.
As for Halers, utter rubbish based on my experience. I fit ecostar for preference now and have not yet had one problem.
Yep I have never fitted Halers either; these were done as part of kitchen refit. Though a fair few sparks seem to swear by them. Not heard of ecostar but will have a butchers at them.
The gap in performance and efficiency between differing domestic LED fittings would more than likely be negligible in my opinion. I can see this being a more important factor on larger commercial installs though.
I fitted 30 Halers H2 in the auditorium of a theatre, absoloute disaster. We ended up swapping them all out for gu10 halogens after 2 years of constant replacements
Ecostar are made by a uk company called photonstar, they make high quality commercial fittings and have applied this knowledge to making the ecostar range for smaller installations. The big advantage is you can only get them through wholesalers, you can't get them through most online stores :)
I fit either halers H2 pro or if the customer doesnt want the expense a standard halogen fitting with a crompton GU10 LED. The Haler H2 pro come with a 7 year manufacturers warranty. I guarantee the fittings for 1 year and then its the manufacturers. I tell the customer that they MUST send the warranty form off, if they dont they wont get the warranty and if they call me in, it will be chargeable
With the GU10 LEDs in the standard fittings I give a 3 year guarantee. I feel I cant bang on about how great LEDs are and then charge the customer if one fails after say 18 months. My wholesaler is very good about returning duff lamps even after 1 year so my loss is a little time usually after a days work. Having said that I havent had many fail after 1 year anyway
i always think its luck of the draw with some LED lamps. If one had blown after 10 months i would not replace at a cost to me. I would tell the customer to get the receipt out of the handover pack id given them and sort if themselves. If you cant change a lamp in your own home your pretty much screwed in life. However if i was passing/near and they had got the lamp i would fit it for a ÂŁ10 fee.
I returned to the customer this morning and replaced the Lamp free of charge, the customer was so happy that he asked me to re-wire his entire house right there and then which I did... so a small little favour earnt me ÂŁ1000 for a days work! :D
Well... the first bit was true!
Nice money Steve, all in an day. lol
Reply to Blown LED lamp, who pays? in the UK Electrical Forum area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
Heh I know the brochures for courses with stock images of women using tools in random scenarios but when you're there it never happens, it's all...
