Blown Socket- Possible neutral earth issue | on ElectriciansForums
Discuss Blown Socket- Possible neutral earth issue in the DIY Electrical Advice area at ElectriciansForums.net
Caltza
Pretoria, South Africa
Hi Members,
This is my first post, I live in South Africa with similar domestic DB set-up as UK & Australia. Yesterday, we had a kettle blow the receiver socket in the kitchen and this tripped the earth leakage switch, I am trying to see if I can fix this, I have sa fair degree of knowledge when it comes to home electrical work. The earth leakage switch keeps on tripping ( it only powers the plugs) I tried removing the affected socket and by-passed the receiver, but to no avail.
Earlier on in the afternoon the EL was tripping whilst we where using a spearate plug to power the lawnmover, im not sure if its related to the issue, but I was able to correct this issue. I highly suspect a neutral earth issue but I cant visually see any earthing at the socket.
How possible is it for me to find the fault here if it is neutral earth?
Thanks,
Hi - sometimes the fault is not easily found without test equipment, sorry. You’ve tried removing all the appliances and can’t narrow it down, next thought - any holes drilled lately? For picture hooks etc? What happens when you turn on the oven?
Reply to Blown Socket- Possible neutral earth issue in the DIY Electrical Advice area at ElectriciansForums.net
2 3
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
