Board Change | Page 2 | on ElectriciansForums
Discuss Board Change in the UK Electrical Forum area at ElectriciansForums.net
Market Harborough
Hi,
Went to look at a board change this morning, all seems fine, nothing untoward, only thing was on the downstairs ring the CPC continuity was higher than I would have liked.
r1 = 0.39
rn = 0.41
r2 = 1.44
I was half expecting around 0.75 ish, how far over the expected do you accept without investigation? I would imagine its probably just a poor connection in a socket somewhere. Usually I would look and see if i tighten them all up a bit, but would it be acceptable to change the board would you say without doing anything and just making a note of it?
The Zs on all sockets were fine, just the continuity on the ring that's all. So really just wondering if you have an upper limit as to saying "yeah that will do" before you look into it.
Where do you draw the line of acceptable?
Cheers,
My house was done like that until I changed it, it's only when I thought I'd replace all the faceplates then thought, damn who did this, it's a bit cowboy ish IMHO.
I don't know about cowboyish, it was a fairly common practice once. Usually the cpc which goes to the box first will be an unbroken conductor just folded to fit in the terminal, pretty unlikely to cause a high resistance.
I agree fully that it is not the right way to do it these days though.
Agreed it was common practice. Late 80's to 90's. I never did.
That's how I was taught in college in 2011. WAS...
Because earthing of back boxes was standard practice in those days, it's how I was taught.
These days it is not a requirement, but many people still consider it to be good practice.
It is a debate that has gone on since time immemorial, and I don't suppose it will stop anytime soon
true but cpc in/out on socket then flying lead to backbox would be my choice
Reply to Board Change in the UK Electrical Forum area at ElectriciansForums.net
What I find a little bit interesting is that there was an era of MFT's e.g. Robin, early Kewtech that tried to do non-trip loop tests using D-Lok...
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
