board fed from time clock | Page 2 | on ElectriciansForums
Discuss board fed from time clock in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Finding an auxiliary block that has 3 N/O contacts will take some sourcing ...................normally they are 2 N/0 and 2 N/C, which is probably why 2 were recommended. Plus you need the auxiliary rated 24 amps ( can't get my head round that value) and most auxiliary are for control so that would be something else not exactly of the shelf
4 N/O contacts is not a problem but I take on board that not many aux blocks will carry 16+ amps.
I still maintain get a proper timeswitch. I have a nice 80A unit in my meter box, although I don't have storage heaters any more so it sits there looking pretty.
Additionally, once you start fitting contactors, then the client has an additional "moving part" in their system. A few years down the line as the contacts wear/burn out they will have more expense.
G isn't the No 13/14 on an Aux normally what we use to call in them there olden days a "pulse" contact. I remember the dim and distance past when doing these being told that you never connect a load onto it.
I have used many forms of aux in industry over the years, some 2/2, some 4 n/o and some 4 n/c. I realise everybody's experience will be different. One thing I did learn after many night-time call outs was this...Always use the next contact size up from that which the manufacturers say will work....
Reply to board fed from time clock in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
You only need to switch the lines and the contactor is rated per pole so for example a 16A four pole contactor would be fine.
OK for a simple load. What happens with (say) SMPS LED drivers ? I'd guess : Loads aren't perfectly balanced, especially during startup, so one...
