Boarding attic, wires over joists, advice needed. | Page 2 | on ElectriciansForums
Discuss Boarding attic, wires over joists, advice needed. in the UK Electrical Forum area at ElectriciansForums.net
wales
Hi there I’m boarding my attic and the wires are going over the joists,
I know I can chisel a grove in the chipboard board or take the wires out of light fixture.
I was just wondering would it be a bad idea just to made a grove in the top of the joist with a round rasp just big enough for the wire to sit in the joist below the board?
I know you can also drill hole in middle of joist just wondering is it a bad thing to make notch in top of joist?
The metal safe plates are for joists which are the wood that downstairs ceiling is screwed to from below and upstairs floor is sat on from above. These are not the same as roof trusses which I have always been taught not to cut or drill. I would just stand the boards off the trusses i.e. lift them up to create the space. You can either counter batten with 2x1 or something or buy some of the little stands you can get
Reply to Boarding attic, wires over joists, advice needed. in the UK Electrical Forum area at ElectriciansForums.net
K
Advice needed - questions before getting new bathroom fitted Hi all, hope this is okay to post. Just over a year ago, I took on my dad's old...
KamikazeBob
K
It's defn a pain though the odd time my reciever goes down and it stops done the odd plane that happens to be using mode s from showing on the...
