Hi there I’m boarding my attic and the wires are going over the joists,
I know I can chisel a grove in the chipboard board or take the wires out of light fixture.
I was just wondering would it be a bad idea just to made a grove in the top of the joist with a round rasp just big enough for the wire to sit in the joist below the board?
I know you can also drill hole in middle of joist just wondering is it a bad thing to make notch in top of joist?
I would say it would depend upon how deep the joists are. They should ideally only be drilled or notched in certain locations. If you google, where to drill joists, you should find plenty of guides. You should consider using safe plates as well, if you go down the notching route.
Hi - I don’t run twin and earth cables in joist notches due to the risk of damage from a future nail or screw. Here’s an extract of the Electrician’s Guide to Building Regulations on the topic.
Are the rules you quote the same for rafters, joists are not the same as roofing trusses are they? just wondering, after all they are not as robust as floor joists. smaller in all planes especially in new houses.
Are te rules you quote the same for rafters, joists are not the same as roofing trusses are they? just wondering, after all they are not as robust as floor joists. smaller in all planes especially in new houses.
good point. i'd be wary of drilling modern roof trusses. the ideal way would be to notch and fit plates. that also means that the cables don't need disconnecting.
Hi Pete - I hope you are well :) .
The minimum depth for unprotected cable should still be 50mm below the surface, but you’re right the strength of the beam needs consideration, which would likely be on a scale of ok to oh dear :) .
Yes Mate I'm fine Ta you OK?
A quick search for "safe plate" brings up a range of metal plates you would use to help protect any cables below. I'm not sure quite how much nailing they would take, but at the very least they would show up well on a metal detector if anyone was being diligent before hammering stuff down:
The safe plates I've used are of thick metal and would prevent nail penetration, however I think the important point here is that the OP should not be advised to notch or drill roof timbers under any circumstances. A safe plate would involve notching.
I assumed a safe plate over thin packing material (say 12mm or 19mm thick wood, enough to gap the cables) instead of raising it by the (50mm - floor thickness) ~30mm otherwise needed?
[automerge]1587979567[/automerge]
I agree that they should not notch the beams!
I recently did my attic which had 16 mm conduit running over the joists I used 38x19mm roofing batons and put them on top of existing joists leaving a gap where the conduit crossed a joist this saves you trying to reroute cables and just screw them in place.It may be more expensive but it will save loads of time jd
The metal safe plates are for joists which are the wood that downstairs ceiling is screwed to from below and upstairs floor is sat on from above. These are not the same as roof trusses which I have always been taught not to cut or drill. I would just stand the boards off the trusses i.e. lift them up to create the space. You can either counter batten with 2x1 or something or buy some of the little stands you can get
wales
Boarding attic, wires over joists, advice needed.
cctvtobeornottobe,
robd,
