Hi all, first time on here and I need some advice please.
My boiler keeps tripping. After the original boiler installers came to fix it and declared the problem was due to faulty electrics, I had it rewired onto its own RCD circuit, and it was fine for a while, but has now tripped every day for the last week.
I need to prove that it is the boiler which is at fault but need to check first that the electrics cannot be called into question.
The boiler is on its own circuit so am I right in thinking that there's nothing else electrically that could be interfering?
Also the consumer unit and boiler are both in the garage. It has been damp the last few days and although there's no water leaking in or anything, the fuse spur is on a single skin exterior brick wall. Could this be causing any issues?
The main problem is that it is intermittent. The boiler seems to trip around an hour after coming on in the morning (when its cold and damp), but within another hour or two, it works again. If someone came to look at it while it was working, would they be able to even begin to locate a potential issue with the electrics?
Thanks for reading & helping. This whole situation is very stressful and the boiler installers (A Shade Greener) are being very difficult / unhelpful.
Nick
Nick
