Corbs
It is an old boiler , 15 years old.
still no pilot light elec ignition eg sparker
if the pump isnt running its a calling issue eg not calling for heat so prog or room stat if no hot water as well prog
but if the pump is running either overheat or internal boiler fault (somthings holding it off eg no pilot light on the older ones)
under the front cover any lights on op?
Yes it's 18yrs oldIt is an old boiler , 15 years old.
Sorry my mistakeYes it's 18yrs old
you should be able to press the red button in if its overheated / faulted out if not check is your pump running
It's solid, won't push in
yes you should be able to feel it should be making a vibration / light on
I'll call him out tomorrow, I appreciate the help, thanksso its definitely a boiler fault and not a controls issue time to call the gas safe engy out
