Boiler programmer wiring | on ElectriciansForums
Discuss Boiler programmer wiring in the DIY Electrical Advice area at ElectriciansForums.net
Rawsox8
Colchester, Essex
Ok, so im no stranger to basic electrical work, changed a few plugs, rose lights, and even a 3 valve port on a central heating system ha.
I want to replace my old Myson microtimer for a more modern one.
Issue i have is the wiring.
The newer ones have N L 1 2 3 4 E
My current one has N L 1 2 3 4 5 6 E
All apart from 6 is used.
Live is joined to 2 and 5 via a brown cable.
Any idea on how i would wire this up correctly?! I will attach a few pictures.
  • [ElectriciansForums.net] Boiler programmer wiring
1 is HW on, 3 is HW off, 4 is CH on.
Refer to the wiring instructions for your new programmer as to which terminals to connect to.
6. But you don't have.
Google Horstmann 525 wiring diagram.
Reply to Boiler programmer wiring in the DIY Electrical Advice area at ElectriciansForums.net
Commonly known as double knock, some pirs have a latch on time delay for a few seconds, giving time for the 2nd one to activate .
Certainly is!! And another thing .......... On the old Hive receiver the relay common is a separate terminal, whereas on the new Hive presumably...
