darkforces
I'd get another heating company in to look at it.
It could be a number of things.
Low gas pressure, air flow sensor, dirt on the thermocouple, could even be a blockage on the exhaust.
Check PM's please Mark
With regards to op,think problem is with boiler not external controls,seems boiler is stating and going through its self check process and is sensing something is not quite right,is sounds as one of the sensors itself has a problem
You do not say what boiler it is but the fact it is in a out house this time of year and problem only first thing would point to a possible damp/condensation problem in the boiler,it is not good to have electronic equipment outside in a out house,indeed as you know,delicate equipment should be removed from vans at night this time of year
I would build a insulated box around the boiler,this may well cure the problem and will increase life span of delicate components found in todays boilers
How about as an experiment you get some sort of heater in the boiler house for a couple of nights to see if the fault is temperature related??
OK ... it's going to cost you some money in running costs for the heater, but it could save you in the end if it points you in the right direction.
"Hello puddle",
Please don`t be offended by this - your suggestion quoted below - depending upon what type of Boiler this is - could cause a Dangerous situation to occur regarding possible requirement for Combustion Ventilation / Cooling Ventilation.
Quote:
`I would build a insulated box around the boiler,this may well cure the problem and will increase life span of delicate components found in todays boilers`
I know that you are suggesting this to try to prevent Damp getting to the Electrical Components - BUT If this Boiler is an Open Flued Type - Often found installed in Out Buildings - it would REQUIRE Combustion Ventilation - Negating that by `Closing In` the Boiler in an `Insulated Box` would either cause it to not Work at all - because of NO Combustion Ventilation - Or would cause `Incomplete Combustion` and the production of Carbon Monoxide - Very Dangerous - even in an Out Building.
Even If the Boiler is a `Room Sealed` Type - NOT an Open Flued Type - some Boilers Require `Cooling Ventilation` around the Casing - otherwise the Boiler Case SEAL can overheat and therefore Degrade into a Dangerous State - meaning that it No longer Seals - this can not only affect the Combustion Process - but can also allow Products of Combustion to then Leak Out of the Boiler Casing.
Please don`t be annoyed about My Message - As a Heating Engineer I cannot read something like what you suggested and just Ignore it - when there could be a Safety Issue.
Chris
Obviously any insulated box/compartment constructed around the boiler will have to meet current regulations and MI and apologies that I did not explain this as succinctly as yourself,however as a ''heating engineer'' I feel no problem recommending the above,constructed in the correct way
As mentioned ,I do not know make/model of boiler,once this is know,any requirements can be raised
I like the idea of placing a heater close to unit over a few nights to see if any improvement on initial start up,obviously as long as it meets with current regulations and mi
:cyclist:
