Boiler trips rcd within 30 minutes | Page 2 | on ElectriciansForums
Discuss Boiler trips rcd within 30 minutes in the UK Electrical Forum area at ElectriciansForums.net
A
Andystraughan
Hi guys
im going to have a look at a job tomorrow night. The lady states for the last 10 months! The boiler has been tripping the rcd on and off. You turn the central heating on and it trips in about 30 minutes. The women was a bit vague over the phone as she also says it trips with hot water being turned on as well. Some times 30 minutes some time 10 minutes sometime straight away.. she only wants me to have a visual look as i mentioned as soon as tools/tester comes out charges apply. Its a baxi boiler 5 year old. Wiring is ancient (her words) my question is what quick checks can i do to see whats causing it? Can it be the switching when the room has reached desired temperature? Simple bad connection? She also mentioned she has really bad damp. And had a plumber out to fix a gas leak, he looked for damp behind spur and said the wiring is shambles (his word) just the 30 minute rcd trip time is a bit confusing so any ideas on what to look out for would be great. This is tomorrow nights job Remember no tools/no megger Maybe a screw driver lol
cheers
andy
Hi guys
cheers
andy
I can understand a boiler tripping an RCD off but can't for the life of me understand how the Hell it can trip it back on!!!
@ OP. if still here. if you don't want to be getting the tester out, just clout the valves, pump, and the boiler pipes with a hammer. Pi$$ in the header tank, then charge ÂŁ250. ( oh, sorry, your a sparks, not a PLUMBER )
Water and electricity don't mix.
Find where uncontained water is near to electrical connections on the boiler circuit and you'll find the problem.
It'll be a small leak hence the time delay.
Reply to Boiler trips rcd within 30 minutes in the UK Electrical Forum area at ElectriciansForums.net
Im not as clever as you guys. I would be doing what somw others have said, I would be leaving certain items switched off for a period of time...
