Boiler wiring - Danesmoor + 2 external pumps
Hi Lee,
yes it is this actual one, that was me being tired and it has got the black control box dangling inside the boiler, so I have it already wired effectively (I guess) and just need to hook up the L/N/E to the new boiler from this?
The control box/wiring centre should be fixed external to the boiler not dangling inside.
Just read the OP again and your old boiler had an internal programmer so you are going to have to get a two channel programmer. Do you have a room thermostat and cylinder thermostat?
I will get a 2 channel programmer - would you recommend a particular make - in terms of reliability and ease of use, I also need a 1 channel for the immersion?
There are room and cylinder thermostats which wire into this grundfos box.
You really need to get an electrician to sort this out, especially if you want to incorporate control of the immersion heater into the system!
No you will need a two channel programmer if you want to time the heating and hot water individually. These 3 below are the most popular makes my personal preference is the Honeywell ST9400C.
Edit:immersion? This should be separate as the boiler should be heating your hot water.
https://www.plumbarena.co.uk/produc...5VDHxFpb74a2mFft3SsN0aAua78P8HAQ#.VckIf9q9KK0
Drayton LP722 (Mk4) Programmer | Programmers | Screwfix.com
Danfoss FP715
Danfoss FP715
I saw the drayton, looked nice, will look at the others - thanks
And immersion for the element in the cylinder, just in case the boiler fails at least I have a fallback.
