Boiler | on ElectriciansForums
Discuss Boiler in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
E
eco-tech
Eve All,
Advice on this issue please.
Boiler in en-suit. I have a new feed from the C/unit in place to a spur.
Number 1 Problem Can i just spur of the ringmain for the boiler supply ?
Number 2 the controls for the boiler is a 5 core so would i need to locate this away from the en-suit ?
Number 3 If the boiler is enclosed in a cuboard in the en-suit can i wire the controler in there ?
Number 4 If i can spur of the new ring main for the Boiler can i use the old boiler supply for my new radial to the lighting ?
Any help lads !
For number 3 its yes its a radial back to the c/u as it was the old feed for the boiler
For number 2 (locate the control away from the en-suit if no cuboard was to be built in the en-suit).
number 4 sorry not 2
Im assuming the five core is from the programmer to the boiler control box, ( ie pumps, valves, stat etc ) these I would assume have been locadted in the same proximity as the hot water storage tank so installation dictates position
Reply to Boiler in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Outside socket… ok. But you say the fcu for boiler is beside the outside socket… is the boiler outside too? FCU’s have an IN and an OUT… the OUT...
Thanks I understand it now just getting to grips now with the different types and different ways of wiring them
