Bonding 10mm oil pipes | Page 2 | on ElectriciansForums
Discuss Bonding 10mm oil pipes in the UK Electrical Forum area at ElectriciansForums.net
tylers green
Hi
Never had this situation before,I'm changing a csu in a property,TT,no probs.
The main house has a 10mm oil pipe feeding an AGA and a boiler ( I can only gain access to the aga pipe),this is being fed from one oil tank,the second oil tank feeds another boiler at the other end of the house.
The property was split in two some years back for a grandparent hence two oil supplies.
The tanks are situated in the garage of an out building which has its own supply via a Henley block at the main house intake point.
Question; Can I bond both oil pipes feeding the main house at the secondary csu,out building MET,as the pipes are 15mm,or do I have to try and get a bond where it enters the main house,where the pipe is only 10mm,and would probably flatten if I put a normal strap on it.
Has anyone had this problem,I have heard of someone using an micc P clip to bond a 10 mm oil pipe.
Any help would be appreciated
cheers
Reply to Bonding 10mm oil pipes in the UK Electrical Forum area at ElectriciansForums.net
L
Underground oil tank feed problem This unit is located in France where they use diesel not kerosene. The feed from the underground tank is not...
LostinFrance
L
C
Noisy main cold water pipe, my plumber hasn't heard this before. Hi Folks, Would like to cast the net far and wide to try and get some resolution...
ComfortablyNumb
C
