Bonding central heating pipes | Page 2 | on ElectriciansForums
Discuss Bonding central heating pipes in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Seem to recall reading somewhere that this was not permitted,as it was not possible to confirm that the minimum size of bonding conductor was used....
An nic inspector once berated a firm I worked for because they did just that
I cant remember his gripe, but perhaps there may be problem with the contact area not being sufficient
Just a stab in the dark
It would seem to me that the connection area is only being made where the screw end presses down, and may not be sufficient
I only ever do this if instructed to.
Whan I do it, I link the bands of the earth clamps together by passing the end of the first one through the next and so on.
I then attach the earth conductor to just one of the clamps.
Sorry i'm being a bit thick, So you use the strap as the conductor?
No project I've ever worked on would let you get away with that.
Reply to Bonding central heating pipes in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
At least you didn't come home to frozen or burst pipes.
Update. Went back today as it was popping the other RCD post move, again intermittently with no real pattern. Typically overnight but not every...
