on a number of pir for commercial premises i have found main bonding i.e gas/water has not going directly back to the MET instead they have taken the bonding cable to a sub distribution board or below it to the external earth terminal block. which is closer than the main intake position where the MET is.I think the principal is that as long as the swa amouring equates to the correct cross-sectional area of the bonding cable which then goes back to the main intake position where the MET is ,it is ok!!I do not think this is acceptable in the regs but cannot see any valid reason why it cannot be installed in this way???This scenario is where the sub board and main intake are in the same building.I presume the MET is classed as being at the main intake position and not at a earth terminal block beneath a sub-distribution board.Could anyone please clarify this and perhaps quotte regs no please.
