I'm just reposting this which is what I posted on your thread of the same title .......
I've just last week been through all of this at my mate's house.
He build an extension on the side of his house to make a garage with utility room on the back and an extra bedroom on the top.
There was no gas supply to the house as the previous owner wanted it to be all electric, so we decided the best place for the gas meter would be in the garage near the front door, and the boiler in the utility room at the back of the garage.
My mate dug the trench for the gas supply pipe from the front of the garage to the street, while I installed all the carcase pipework from the intended meter position to the utility room & then on to the kitchen. (Yes, I am retired, but I am sufficiently experienced and still qualified to carry-out certain work.)
Contractors then arrived to lay the yellow MDPE (plastic) pipe in the trench, then in a GRP sleeve up the wall of the garage to a height of about 300mm where it was connected by means of a plastic connector to a steel pipe passing through the garage wall. It then continued in steel to the proposed position of the meter. So, all the way from the street, it is yellow plastic and is still in yellow plastic - with a GRP sleeve - until it enters the garage at a height of 300mm from the floor.
The water main is also MDPE all the way from the street to the main stop cock in the kitchen, and from there the water is run in copper to the boiler and from the boiler, but everything else is run in that Godawful plastic rubbish.
The electricity supply to the boiler is by means of 2.5mm 3 core flex through a switched fused spur fitted with a 3 amp fuse. From the switched fused spur we have 2.5mm T&E running back to a 6A RCBO in the CU.
On Friday, British Grasp arrived to supply & fit the gas meter - well actually they sent a young lass who looked like she left school the week before and was from Bury St. Edmunds, so there was a language barrier there straight away!!
Anyway, she managed to "fix" the gas meter to the brick garage wall with plasterboard fixings and then seeing no sign of a bit of 10mm green / yellow bonding cable, proceeded to give is a lecture on the importance of this "earthing" !!!
I just nodded and smiled until she had gone. Then I proceeded to fix the meter to the wall properly .........
