Stroppy
Do you neeed to bond a metal suspended ceiling grid when it will be covered with plasterboard?
My colleague says no, as it is inaccessible (unlike if it was removable ceiling tiles), and therefore not an extraneous conductive part, but I say it should be bonded as it has cables running through it which may be prone to damage by plasterboard fixers, potentially livening up the grid. Even if you don't have to, I would think it would be 'best practice' to bond it, as the nearest part of it to the MET is probably less than a metre away.
