Bonding to Gas and water am2 | on ElectriciansForums
Discuss Bonding to Gas and water am2 in the The Welcome Forum area at ElectriciansForums.net
Kent
hi all,
I have my am2 coming up. Just going over a few things. I am correct in saying that the Gas bonding would terminate in to the clamp below the joint, and not above it?
Also, I was going to use one continuous length of 10mm is this allowed, or is it better practice to use to lengths?
Regards
Bond needs to be on consumer side not the meter providers side, one cable is fine if unbroken, but i would install 2 and labell them, thats personal choice
if the supply is from the bottom, then the clamp needs to be below the branch joint.
I thought he was referring to bonding the gas and water together
yeah i know. the idea of using a single cable, unboken, is to prevent wet-pants from dissing one service when messing about with the other.
Are you trying to say wet pants doesn't reconnect bonds? lol
Bond needs to be on consumer side not the meter providers side, one cable is fine if unbroken, but i would install 2 and label them, thats personal choice
2 cables are OK by the regs BUT best practice says a single continuous cable is better.
hi all,
Regards
Consumers side of the intake
1 Bond to the H2O and 1 bond to the Gas= 2 conductors it would need to be continuous, which would be difficult if the gas and water entered the building on different sides of the building, can you show me where it says 1 conductor is best practice Murdoch please?
Sizing main protective bonding conductors - https://www.voltimum.co.uk/articles/sizing-main-protective-bonding-conductors
Reply to Bonding to Gas and water am2 in the The Welcome Forum area at ElectriciansForums.net
Indeed it would be. But that would mean having 2 things to disconnect instead of one. More margin for error. Of course, any diligent spark would...
loz2754
L
