sparkyork
hi all, just been on a job today altering a ring main in a utility room and moving the lights around a bit. was waiting for a plumber to get out me way so went for a wander round.. i then found an oil tank in the back garden with no bonding to it. water has a 10mm. consumer unit is a large mk sentry (my favourite!) so im fine for making stuff rcd etc. the board was changed january this year and i said to customer that they should of bonded the oil at least???? shall i phone them and see if they will do it!??
would fancy doing it me self but it looks a T$at to get to and customer said just leavr it!!
also not broke the seal on the fuse yet to see what raiting it is. but the tails to the board are in 16mm and main earth is 10mm, on a tn-s system. if the fuse is 60A am i right in thinking that 16mm tails and 10mm earth are ok?? but if bigger fuse then earthing is defo undersized??
comments gladly appreciated
