bonding | on ElectriciansForums
Discuss bonding in the Australia area at ElectriciansForums.net
soulman
Durham
hi Can someone please explain what the difference is between supplementry bonding and cross bonding and an example of when you would use one over the other
cheers
Supplimentary bonding connects directly to the electrical system, eg a 6mm cable running directly from an electric shower back to the MET.
Cross bonding keeps everything at the same potential, eg connecting a stainless steel worktop in a kitchen to a metal water pipe, or bonding between 2 parallel water pipes.
Supplementary bonding is in addition to main bonding and may be required in special locations as defined in Bs 7671.
Supplementary bonding links conductive parts in the special location with extraneous conductive parts.This is because of the increased shock risk in special locations.
"Cross bonding" is a mythical practice which is still unessesarily carried out at boilers and kitchen sinks etc......Main bonding and supplementary bonding are the only requirements in the BRB.
I'm afraid NovusSparkus's description of supplementary bonding is not correct......in the case of a shower the supplementary bonding would link the earth terminal of the shower...(a conductive part).and any other conductive parts such as a luminaire..to extraneous conductive parts entering the shower room,(metallic services,such as copper pipes).
[quote ]Supplimentary bonding connects directly to the electrical system, eg a 6mm cable running directly from an electric shower back to the MET.
[/quote]
Supplementary bonding doesn't go back to the MET, it would go from the bonded source back to a part of the installation and connect with the cpc. I believe.
Well i wasn't too sure about that but my point was supplimentary bonding connects directly to the installation, whereas cross bonding connects between extraneous conductive parts.
Reply to bonding in the Australia area at ElectriciansForums.net
Hi All, Looking for some advice into my build. What I've basically done is add additional RCD protection to my 100% off-grid 12V 3300W Inverter...
If you can see a piece of plastic entering from the ground then (as cliff said), it does not need main bonding. I think (not sure) this is reg...
