Haha, ....I've got news for all you disbelievers, ALL final circuit conductors on every prestige project i've ever been on, or seen have been connected using crimped flat Pin connectors!! Literary thousands upon thousands of them all the way up to 16/25mm.... after that, crimped lugs!! All or the vast majority of the final circuit conductors are multi stranded, similar to what you find in SWA cable conductors. The correct crimp connector is those with a flattened end connection. Even normal ferrules where the conductor passes through the connection area can be relied on, using a good crimping tool....
Damage as seen in the OP photos, is far more likely to have been caused by either a bad crimp, or loose terminal connection, and probably the latter, End Of!! I don't know how many times i have to say this, but crimped connections made with ''Good'' quality crimps, and a ''Good'' crimping tool that deforms the conductor(s) within the crimp can't be beaten!!
