Guest viewing is limited
Hi Folks
TLC have bootlace ferrules in French or German colours. Is it legit to use these in the UK? If so, is either preferable and why? And why have these not been harmonized?
Just to be clear, when I suggested they should be harmonized, I didn't mean according to polarity, I just meant the sizes would each be coloured the same across Europe or the world.
just fit whatever ferrule goes round the cable. hit with a hammer.jobs a good 'un. oops, thought i was on the plumbers forum.
Not sure uninsulated and insulated are the correct terms for boot lace ferrules?
The little coloured plastic part is hardly insulation.
Saying that, I prefer the insulated ferrules as the plastic part allows for easier insertion of the wire.
Seems a very valid point. I mean Shirley if you just strip the right amount of conductor insulation in the first place there's no need for insulated ferrules. Where do you buy your uninsulated ones?
RS or get wholesaler to get them, they are really useful for small terminals and for 13A plugs if I'm in a good mood.
That's what they are called by the manufacturers.
Aberdeen
Bootlace ferrules French or German colours
Selfmade,
ipf,
