Bosch 18V Li Ion Impact wrench | Page 2 | on ElectriciansForums
Discuss Bosch 18V Li Ion Impact wrench in the Electrical Tools and Products area at ElectriciansForums.net
I have used the Bosch one lots of times that's included in the socket set above and had no problems. It looks very like the Bahco one above
Apart from that, I have loads of Wera tools and they have all been very good. but given that you need an adapter, for the Wera I would get the Bahco.
Yep, that Wera adapter was first one I linked to but I don't mind waiting a week for the Bahco if it's a better quality item and the price is almost identical. Which would be your preference?
go for wera then, they both make good tools. (the wera one will probably be a little better, bahco seems to be more available usually)
I see the Wera has a spring loaded chuck whereas the Bahco has just a retaining clip for the bits. I'm not sure if the check would be better at retaining the bits but if it's going to disintegrate with the constant impact then maybe the simpler Bahco is better.
And if you think I'm indecisive when buy tools you should see me in a shoe shop ;)
Reply to Bosch 18V Li Ion Impact wrench in the Electrical Tools and Products area at ElectriciansForums.net
