Bosch D-Tect 150 Wall Scanner | on ElectriciansForums
Discuss Bosch D-Tect 150 Wall Scanner in the Electrical Tools and Products area at ElectriciansForums.net
Market Harborough
Hi,
ignore the price of it, has anyone on here got one?
BOSCH D-TECT150 Digital Wall Scanner: Amazon.co.uk: DIY & Tools
you can get it for under £400.
anyway, I was hanging a TV in a wall the other week, one of those metal frame stud wall things, anyway, customer says here use this, a wall scanner to find the metal verticals to fix in to... Ok I say but I don't trust them one bit.
it suggests there are two verticals approx 400mm apart which I thought ok, maybe it's true, when I dug a hole in the wall to put the dry line boxes in, there were none insight, I even did it again directly below where I had just cut a 2 gang dry line box in and if said it was there.
i said to the bloke, I said I didn't trust them.
anywag, if you spend £400 notes on one, are they better?
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Reply to Bosch D-Tect 150 Wall Scanner in the Electrical Tools and Products area at ElectriciansForums.net
How did it go?
