bosch GOP 10.8v | Page 2 | on ElectriciansForums
Discuss bosch GOP 10.8v in the Electrical Tools and Products area at ElectriciansForums.net
Hadn't seen this thread, but bought one today for using to chop dryline boxes. Have christened it by using it to sand down a table at home but look forward to using it on site properly. Seems a brilliant bit of kit so far.
I bought a GOP10.8V, and aside from being a handy tools to cut plasterboard boxes out, and the odd sanding job, it's had very little use.
I'm still after a half decent tool for cutting the ali rails on suspended ceilings for trunking drops - anyone have any suggestions?
That just prompted me to take mine to bits and have a look at it. In the head there's an offset cam driven by the motor, the connection between the motor section and offset cam is via an hex "nylon" bush driven from the hex head on the motor end. Nothing too expensive to fix it. I say nylon, not sure what the material is as it's embedded in the head.
I use the GOP for the ceiling rail chopping. Works a treat.
A cracking bit of kit.
I take it you had a "day at races" then? :)
Yep, with exception of a larger sized Bosch L-Boxx, I only bought what I went there for.
Oh, Elliotts tools in Fratton are having a sale on all this week.
U use a pair of Gilbows, if it is round conduit, then a faint pencil mark on the edging either side of the conduit, then snip the edging with the Gilbows angled into the cut out section. As long as you always keep the top blade resting on the section you do not want removed so the bottom blade cuts up the edging on the part to be removed, you should always leave the edging looking good.
Cheers, so basically big-assed version of a tin-snip then :) I only need to do it occasionally, and it's normally for flat trunking as it's for data installs. Still, there's a part of me that says that if the job can be done with a power tool, then that is the right and the proper way to do it. My experiments with a angle grinder were not hugely safe, and required patching the wall ;)
The fein is ÂŁ600 had a play with one last week and its an amazing piece of kit. Would love one but it's ÂŁ600 (or ÂŁ500 without blades)
Will probably get the 110 version for now
ÂŁ600 :rolleyes4: That's insane. Don't quite see how they can justify that.
The only way 'er indoors' would let me buy that is if it doubled as a vibrator :rofl:
Reply to bosch GOP 10.8v in the Electrical Tools and Products area at ElectriciansForums.net
Your biggest mistake is admitting to a mistake.... If theres no witnesses, it didn't happen. However.... A few golden rules.... Never trust...
