Box with telephone wires | on ElectriciansForums
Discuss Box with telephone wires in the UK Electrical Forum area at ElectriciansForums.net
papareis
New York
I have an electrical box on my kitchen wall that I'd like to get rid of.
Can I tape the wires up (separately), push them back in the box, and spackle over it, or is that prohibited as is the case of a conventional 110/120v electrical box?
I may leave some baseboard-mounted telephone connectors in place in other parts of the house.
There are no 110/120v house-wires in the box (photo attached).
I could put a blank cover over it, but I prefer not to be able to see it.
Thanks!
  • [ElectriciansForums.net] Box with telephone wires
Assuming the phone cable is connected, I'd suggest to disconnect it at the other end - assuming you know where that is - before filling in the hole. That way, if someone accidentally drills through the cable one day, they are not going to short out the phone connection.
NB: I had to look up "spackle", seems to be a US term for filler (there was also another interesting urban dictionary definition).
Hard for me, as i am in the UK, but it did once work for the local telephone company here. The reason i asked if there are other working telephones is because phones are similar world over and anything you do here could affect other phones in the house. The only way i know of to do what you want to do is find the other end of the cable in the redundant box. Phones are usually daisy chained in the UK but the could also be starred from a centre point. Ideally you would look to find the other end of the cable in your redundant box, isolated the cable there and then you can chop off the cable in the redundant box and fill over.
Hope this helps.
Thanks!
Tape them up and shove them in the wall. The code book has nothing to do with telephone wires.
Reply to Box with telephone wires in the UK Electrical Forum area at ElectriciansForums.net
I’m a little confused but most electrical companies will probably pull romex cables to each dedicated circuits, so about 10 separate cables. All...
Obviously not a building/DIY forum so will keep it short but yes - we've taken all the floors up. Several joists in the bathroom need doing as...
What is the distance from the point outside the house to the shed?
That’ll teach me to check OPs location before posting. Much of what I said was UK biased, but I guess the physical limitations of space part is...
