BPT Agata VC - Wiring Instructions | on ElectriciansForums
Discuss BPT Agata VC - Wiring Instructions in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
London
Hi all,
We have a BPT Agata VC door entry system and the wiring had come away and I'm unsure on how to re-wire.
Any advice is massively appreciated as I can't find any info online.
Thanks!
Will
[ElectriciansForums.net] BPT Agata VC - Wiring Instructions
look at the other end of the cable. the terminals should be marked there.
Unfortunately there is literally no way of knowing from the picture. You will have to trace the feeds of the conductors to source then work out which is which.
this source?
Reply to BPT Agata VC - Wiring Instructions in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thank you so much for your help with this light work perfect now thank you again much appreciated
I'm dealing with an Omega VSJ843RSG vertical juicer that appears to be dead. The mains switch and fuses are all good. I can't find a circuit...
