Delete.
Discuss Breaker Tripping under unusual circumstance... in the DIY Electrical Advice area at ElectriciansForums.net
Right you are!Hi Martin - if you've an extension lead that might save your back
Also, can you move your PC and plug it into a downstairs switched socket on the ring circuit supplied by the 32A MCB to the right of the 16A one? Then do your x 10 switch on test. Take a picture of the socket you use.
This, I'm not sure about. I'll have to have a look. I see how that would make sense. Good shout!What switching are the sockets ? are they single or double pole
If there is a staggered opening of the switch contacts (live and neutral of the socket)and they do not break at the same time,its possible the Rcd sees this as a imbalance with the type of load being switched
Have you tried inserting the power cable/plug as a power on method before trying the switch, or only after using the switch has tripped the breaker. I ask this because (at least some of) the large inrush current will charge capacitors in the PSU which may have built up some charge from power ups that have tripped the breaker by the time you resort to unplugging and re plugging. I have also been told in the past that inrush curent can vary due to the point in the a.c. mains cycle when the circuit is made.
The arc damage you see on the plug pins will only get worse, especially if used to make/break a large inductive load. The plug should be replaced, and any sockets it has been used in should be checked for similar damage.
Reply to Breaker Tripping under unusual circumstance... in the DIY Electrical Advice area at ElectriciansForums.net
