Breaking strain of 10mm T+E | on ElectriciansForums
Discuss Breaking strain of 10mm T+E in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
South East
Had to give a broken down mate a tow last night - couldn't find a rope so used a length of 10mm T+E (old colours). Any ideas of what the actual breaking strain might be? (let alone the legality)
If you look in the book anything over a tonne then you have to use 16 mm or just towing a shopping trolley with a mate then 1.0 mm will be fine but remember to get the polarity correct otherwise it won't matter a sausage
Reply to Breaking strain of 10mm T+E in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
