- Joined
- Feb 17, 2012
- Messages
- 532
- Reaction score
- 230
Yesterday I went out to a small block of flats to deal with a fault on part of the landlords supply and discuss fitting a fire alarm system. I pointed out to the landlord that the building as a whole, 4 flats and the communal area had never been tested and that he should consider having an EICR done. He informs me that he has a contract with British Gas who do the gas checks annually and check the electrics every 2 years so he is covered. This for 4 flats and the landlords supply takes, apparently about an hour!!!!!. Well I thought I was pretty hot but thats 12 minutes per system. I`m assuming that they do a quick Zs and an RCD test then tick the box and walk away.
Anyone else come across this?
