Rods should be a minimum of 2x depth apart from memory from 7430, though I would need to check, that is what I was taught and have always worked to.
Can't look it up now go to go, wife has just been ill.
That's a new one on me, I shall try and get some more research into the subject done
Just checked Guidance Note 8 which says the spacing should be at least equal to the length of the rods used.
Edit: Page 28 GN8
All very much depends on the the resistivity of the soil the electrodes are being used in. With a good soil resistivity the spacing between the earth electrodes need to increase to avoid electrode zones of influence overlapping.
My general rule of thumb for small installations is 1.5 to 2 X the buried rod length when soil resistivity isn't known....
My use of 8' and 10' originates in an entry in Stubbs' electrical encyclopaedia, which although it is a bit out of date seems to concur with modern information I have read on the subject.
Stubbs may be old but it’s a mine of information that’s still relevant. Electrical theory doesn’t change.
Up until recently (last couple of years) i'd never seen a 1.2m 5/8'' rod, and was told at the time they were extention rods only. I've still never seen these 3/8'' twigs/test spikes they call earth rods!!
The majority of the earth rods i've used over the years are generally 3/4'' X 2.4 or 3.2m extendables with the odd project using 5/8'' X 2.4 or 3.2m extendable.
British gas TT earthing and rcds
pope,
Engineer54,
