British Standards not highly regarded | Page 2 | on ElectriciansForums
Discuss British Standards not highly regarded in the UK Electrical Forum area at ElectriciansForums.net
KennyKen
Nearly Esteemed
Australia
Thought this would be the best place to vent.
As most of you know I work abroad. Australia. So during my long arduous Nightshift I got talking to some international sparkies. Three Aussie and One Canadian. The old conversation of Standards got brought up. To which I said that I thought very highly of British Standards considering I'm An UK time served Sparks. I got a resounding laughter from the Aussies who's first reply was "You guys still wire Ring mains pre 2nd world war" and what's stopping one leg to become live blah blah blah.
So after my long explanation apparently they see British tradesmen as a bit of a joke. Everyone has a right to an opinion but I found quite astonishing espically I find the British work to be of a higher standard. Plastic conduit is used over here for industrial and commercial installs. Two pin plugs on certain equipment which are flimsy. Most Socket and three phase outlets are plastic. No metal outlets for industrial premises. No fuses in plugs. Testing is not as thorough. Catinary Wire Installs used for cable containment rather then tray. Hardly any use of SWA except where I'm working. In normal circumstances it's orange flex. 240v on building sites. When I said we use 110v. Well they couldn't quite grasp the 55v safe touch voltage.
Rant over.
I remember, on TV years ago....an Aussie plumber fitting a new bathroom out and scratching his head when he came across a bidet. He ended up fitting it to the wall for use as a pee stone.
They do have a pretty fair sense of humour.
Rant over.
With the jobsite transformers, the UK is the only place in the world that still uses 110V, :D There are those who say North America uses 110V, but they are just showing their ignorance, it's a prewar voltage, it went in stages from 110/220V, 115/230V, to the current standard of 120/240V.
The advice from HSE (health and safety executive) is that tools, plugs and cable designed for domestic use are not suitable for site conditions. You should use cordless tools or those that operate from an 110v (CTE) center tapped to an earth supply system so that the maximum voltage to earth does not exceed 55v.
This system is deemed the safest. 230v onsite backed by an RCD is Illegal on large construction sites... if an RCD is faulty and fails to operate then it doesn't take a genius to work out the possible implications.
Reply to British Standards not highly regarded in the UK Electrical Forum area at ElectriciansForums.net
