BS 1363 socket for EV charger - what kind of RCD? | Page 2 | on ElectriciansForums
Discuss BS 1363 socket for EV charger - what kind of RCD? in the Electric Vehicles Advice Forum area at ElectriciansForums.net
you are very vague on information .
Who me? I thought I'd given all the info relevant to my question? And I don't see how you've arrived at 'try B' from knowing the system and location? From my reading of the regs the only thing that seems to affect the choice of A versus B type RCD is the level of DC residual current. Have I missed something? I do really appreciate your help, I'm just not sure I understand what you are saying and why?
is this garage separated or else.
Garage is attached to house but with no access from one to the other.
yes, please start from the beginning. like I want to put a charging point .to and from .:confused:
OK, will see if I can describe the situation in a bit more detail. I've been asked to quote for a garage installation (currently no power in garage) among other things. The supply is TN-S. One of things that will be used in the garage is a charger for a hybrid car. The charger has a 13A BS1363 socket, so will draw 13A or less (probably close to 13A). I've no plans to add an earth electrode as system is TN-S and as far as I am aware the car will be charged in doors. I'll be installing a CU in the garage (probably 5 way), 10mm2 (probably SWA) fed from 40A MCB in house CU. The will be a 32A sockets circuit and 6A lighting circuit in garage and a separate 16A/20A circuit for the car charging point as required by 722.311. The door frame is metal so will probably be extraneous and need bonding back to the intake. Think that covers it.
Problem is here you are installing a standard 13A socket outlet which could be used for any purpose.
Yes, and the charger could be plugged into another socket. I follow the EV scene a bit on YouTube and the like and EV drivers plug their cars in everywhere - for example when visiting friends they'll run an extension from their friend's lounge to charge their car. Why wouldn't they? The charger has a standard plug on it! Which puzzles me as to why all these requirements are not on the charger manufacturers! But the scope of Section 722 says any socket intended to be used for charging electric vehicles. All that said I don't say any problem with using the charger point for other purposes?
Maybe so you can plug the kettle in for a brew whilst waiting for the car to charge....
Lol! I'll be marking in 'suitable for electric vehicle charging', so hopefully the car will be plugged into this one and the kettle into one on the main sockets circuit!
Reply to BS 1363 socket for EV charger - what kind of RCD? in the Electric Vehicles Advice Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
That was my saying not long ago about TNS to PME system. I would be nice you can ring up the DNO, will the systems being up graded, there is a...
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
