Bs 5839-1 | Page 2 | on ElectriciansForums
Discuss Bs 5839-1 in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Copies of the BS5839 will serve you no purpose apart from bedtime reading.....If you want to be approved in any way, the first thing a trade inspector will ask "do you have the original Reference to BS5839 parts 1, 3 and 6 and SP30" if you haven`t....FAIL...!!
Its a minefield out there. And won't fail as already a member just trying to have a bit more info and read certain reference points
cheers
How can you be a member of BAFE, or any other acredited body without a BS reference....?????
Not a member of BAFE never heard of them. I am an electrician and a member of a competent person scheme. So cover all aspects of electrical work not just fire alarms.
I'm assuming Bs 5839-1 is a copyrighted document and there would be legal issues in the UK with sharing it so thread closed I'm afraid.
Reply to Bs 5839-1 in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It depends very much on what RCD you are using, or even If you are using one. For example, if the RCD is 500mA then a max Ra of 100ohms is classed...
BS 5266-1 Doing a lot of three hour drain. And when the lights fail or so bad they don't show much light (hight ceiling and it's a small LED...
