domapegitashi
I think the installation in a small communal house (CH) is from BS 7671 16th Edition. The consumer unit has no RCD protection on any of the MCB. I think the cable from the feeder pillar is fed into 100A main switch without any kind of isolator. The problem is that those who run those CH, wants to move the bar area from the existing area into the new area within the communal house. All they are moving is few sockets and lights, it means requires few new junction box to connect wires to socket or light.
My main concern is that CH is not rewiring, do you still install as per 17th edition i.e. RCD protection. Otherwise the consumer unit is require to change as per 17th editions.
