BS7671:2018 | Page 2 | on ElectriciansForums
Discuss BS7671:2018 in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If you understand it, can you let me know :)
Well what I seem to have gleaned so far is they work similarly to an RCD, do much the same job, but can't be easily tested for correct operation. They will expand the size of a CU considerably, increase the cost even more, possibly be the cause of frequent nuisance tripping, and they are not even proven to work properly.
I can see some stern opposition from those more knowledgeable than me when the public draft comes out.
See now I thought it was all those plastic CU's causing the fires!
Seems the AFDD, fills the gap between MCB & RCD, and primarily used on socket final circuits, but not exclusively.
I note the Siemens vid shows a corded drill arcing & sparking, causing a AF. We'll all have to go cordless. :)
I'm a bit behind with these new proposals, does anyone have any detailed info about arc fault detectors and their application in the new version ?
The americans have been using them as part of the NEC for a while. In a word they are sh!t.
The yanks don't do testing, but there is no way outside a lab they can be tested if they are working properly.
Reply to BS7671:2018 in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello all easy cert users, ive been using easy cert since 2001 with no yearly subscription. and also found other people looking for older versions...
Spot on The Requirements of sections 1-6 must be complied with in a special location unless its otherwise stated in that part of section 7 that a...
