BSEN 60309 socket for ev charging | on ElectriciansForums
Discuss BSEN 60309 socket for ev charging in the Electric Vehicles Advice Forum area at ElectriciansForums.net
jedisparks
Hi to all,
I've been installing hypervolt and zappi units the last couple of years. Recently a client has come to me with Audi supplied 32amp charging lead. It has a 32amp Bsen 60309 commando plug and what looks like a protective device on the lead, a bit like a granny charger.
Assuming i can deal with PEN fault protection (Matt.e or similar) and max demand is okay (load curtailment not needed). RCD no problem. I can't see why I can't install an interlocked 60309 socket outlet. Client can control schedule from the car. If car manufacturers are supplying these leads, in many cases a wall charger in many cases won't be needed.
Am I missing something? Any thoughts?
Many thanks
If it is a brand new car and that was supplied with it then I suspect it is for emergency charging only as it sounds like a mode 2 charger. New vehicles should not be sold for permanent charging from mode 2 they should be mode 3.
Thanks for your input.
I know that has been the understanding for granny 13amp leads and why myself have been recommending mode 3 in all previous installs too. But, looking 722.55.101.0.201.1 (iiita bsen 60309 is a recognised socket outlet for that purpose with no mention of temporary use only. I'd imagine a commando socket would take load over long without problem. I'm struggling to see which reg I might fall fowl of for installing one.
Cheers
Reply to BSEN 60309 socket for ev charging in the Electric Vehicles Advice Forum area at ElectriciansForums.net
Being both PHEV, do they need much charging? I mean, they are hybrids rather than fully electric. My mother in laws Volvo is a petrol hybrid, but...
You need a CT clamp at main tails, it depends on the rules where you are - you used to be allowed wireliss ones (such as MyEnergi Harvi), these...
