R
RJLewisElec
Hi guys,
First post on here, so apologies if this is in the wrong place!
Tomorrow I need to install a BT Slave socket from the master, which isn't an issue, but as it's a very large house it will be a good 40 to 45 meter run between the two. Will this be acceptable? Will this still work at this distance? If not what are the other options available?
Many thanks in advance!
