Guest viewing limit reached
I can't see any obvious way to turn off the BT with Fon on the router set up/software.
That’s cos anyone with a BT hub router is actually providing a wireless access point for other BT customers. Eg BT with phon - so your router is most likely providing the connection
One way to solve
Change provider, set up access times based on mac addresses
How about setting up parental controls on your BT account page?
Log into your bt account online and activate parental controls, that should also work when using bt wifi with fon
It does the Wifi but not BT with Fon.
The BT helpdesks 2 suggestions were:
1. Opt out of BT with phone every evening and then opt back in every morning
or
2. Turn the router off every evening!
Classy unhelpful suggestions if you ask me!
BT Home Hub 5 question
Computer and Networking Forum
Thread Tags
Octopus,
24Vsparky,
