OK lets look at the claims:
Reduce gas bills by up to 80% -
Unlikely - depends what you spend on water / heating - but then it does say UP TO.
Provides 100% of hot water requirments - Probably true.
Provides Free Hot Water day and Night 365 days a year -
FALSE - it's a Heat pump it has a CoP of -- something so need electricity to run.
Heat Hot water to 55 degrees constantly -
Prossibly true, though an a cold winters day with large useage of water, it'll struggle same as a boiler does!
Operates in all weathers down to -15 degrees -
Probably true though
the CoP will go through the floor - Definitely NOT FREE!
Maintenance Free -
NO - it's just like your cars aircon - it will need re-charging at some point.
Fast Payback Period - Probably True
Qualifies for RHPP and RHI Scheme -
Possibly the first - The second no-one knows ...
Lightweigt Panels Can be Fitted on Wall - True.
SO IF YOU WANT TO STOP THIS IT'S EASY!!
If you've read the REAL code, you'll find you are very unlilely to get certified if you've ever had an ASA ruling against you
So ignore REAL and MCS, report:
G & S Ltd T/A Electricity For Free
18b Wellington Road,
Glasgow
G64 2SA
Phone: 0141 772 7675
report them to the ASA with the MCS Covering letter and that should kill the advert straight away..
Make a complaint - Advertising Standards Authority
and
Step 1 - Advertising Standards Authority
You will ususally be contacted within 48 hours - they do start action pretty swiftly.
