Buck or boost for car lift | on ElectriciansForums
Discuss Buck or boost for car lift in the USA Electrical Forum area at ElectriciansForums.net
Usa
I'm looking for help on fixing a car lift for a customer. He bought a used lift that calls for 30 amps at 230 volts but his building only has 120/208 voltage. Should he have the motor changed out or should I boost the voltage somehow? And what would I need.
Believe it or not it will run at 208vac I do air Conditioners and I’ve never had a problem
Really? It keep blowing the fuse and it makes a really bad sound when running. Could be from the weight of the car.I was always under the impression that you need to be within +/- 5% if the voltage. You could be right. Thanks for the reply
Upizzle I've never wired a car lift but where are you getting 208vac from? Is the shop
call your local parts house and order a 208/120vac to 240/120 transformer you will need a 10 KVA transformer single phase which is good for 42 amps
[automerge]1567556888[/automerge]
Is his shop 3 phase or single phase
3 phase panel
Since it’s a 3 phase you will need a 15 KVA 3 phase transformer 208/120 to 240/120 y connection
Thank you,
[ElectriciansForums.net] Buck or boost for car lift
what do you think of this for just the car lift
[automerge]1567558412[/automerge]
Thank you,
Lift pulls 25 amps @ 230v
Thank you, View attachment 51884 what do you think of this for just the car lift
I’m proud of you and not a bad price and when I done the math on the transformer it is good for 42 amps good luck and your welcome
Dpg that’s an old thread so what did I do for you to do the thumb
It's only a week old, last reply was on the 4th.
I just wasn't convinced that it was good advice to just run it on the incorrect voltage without any further worries or checks.
I agree and I’m not perfect but I have wired split systems HVAC rated for 240vac single phase at Cargill foods with 208vac single phase and the unit is still running 4 years later. I know I make mistakes but I thought that thread was over
Reply to Buck or boost for car lift in the USA Electrical Forum area at ElectriciansForums.net
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
