GuardianAngel
I have an SWA cable running from the CU to the garden that the previous owners had fitted, but no longer worked when I moved in a few years ago, that I want to reinstate.
The cable itself runs from the kitchen where the CU is and is then buried under the floor, under the utility room and shower room and pops out into the garden (I have ensured that the cable is no longer connected to the CU nor anything else in the garden and is fully isolated). I have done continuity tests using a multi-meter and the readings look OK (about 0.4 ohms on a 4mm cable over about a 5m run), but it could do with an IR test.
Given that an electrician is very unlikely to want to get out of bed to just do that one test, and I of course I would expect to pay for that service, I may as well put the money towards buying an IR tester myself. So are there any recommendations for a budget IR testing unit that is reasonably accurate? I have about £100 or so I could spend on it, and I would use it again in the future. I have seen the £15 Chinese ones on Amazon and eBay but I guess use those at your peril, unless they are any good for occasional use?
Thanks in advance.
Thanks in advance.
