building regs for sink | on ElectriciansForums
Discuss building regs for sink in the UK Electrical Forum area at ElectriciansForums.net
N
nicsin02
Hi guys I've just taken over a new housing job and the spark that was there before me has fitted a double socket and spur directly behind a sink in the utility, I know the building reg states that a double socket can't be fitted within 300mm of the basin of the sink but is this the same reg for the switched spur or a multi gang switch, thanks
I do not think there are any specific regulations regarding sockets (or fused spurs) and sinks (so long as the sink is not in a bathroom), however any item installed has to be suitable for it's location and the external influences.
I think Amp David has it right!
I would say not really suitable for such a location, but that woud lbe up to the installing sparks assessment.
Is it possible for these electrical fittings to be splashed with water when the sink is being used?
Reply to building regs for sink in the UK Electrical Forum area at ElectriciansForums.net
There is no reason for an item of fixed equipment to be on its own dedicated circuit just because it is fixed equipment. There may be other...
loz2754
L
