bulbs keep blowing | Page 2 | on ElectriciansForums
Discuss bulbs keep blowing in the UK Electrical Forum area at ElectriciansForums.net
G
garysparky1
Hi all, myself & another spark rewired a large 8 bedroomed house earlier in the year I got a call recently from customer telling me that bulbs keep blowing in 2 bathrooms 4x G9s and a candle bulb in wall light downstairs. The lights are all on the same bank of MCBs RCD protected and on 1.5m2 T&E. I have thought maybe spikes in supply would be the answer anybody got any other take on this problem, any help greatly appreciated
I did a job which sounds similar, 7 bed house with swimming pool house which was 4 bedrooms, kept getting emails saying lamps are blowing.
Checked all the obvious, loose neutral at switch (not possible as in a Wago) and in fitting, checked voltage, 243v so fine there......
We fitted 5 outside light fittings, switched on at the same switch, on a Friday afternoon. By Monday morning they had stopped working.....so drove an hour to the job to be told by the gardener that she had left the lights switched on all weekend, over 48 hours straight.........
Moral of the story is some customers need to be told that a light switch is not just for turning lights ON.......
The vast majority of the time I put this down to absolutely rubbish bulbs which don't last five minutes. Are they incandescent type?
I put one in my front room a couple of weeks back when the low wattage one I had blew after about three years. Two days later it was dead.
They don't make "bulbs" like they used to.
In 1951 my Mum, Dad and me moved into another house and there was a light in the hall ( and everywhere else to of course ) but the "bulb" which was fitted in this light before we got there finally popped in 1973.
Not bad going and proves that they can be made to last longer than the do nowadays, but "they" wouldn't sell so many of them .........
If there are any divers on here they will understand the "fins" "flippers" analogy
one is a dolphin the other goes on your feet when diving
that said, I have given up being uptight about it and call them bulbs
Reply to bulbs keep blowing in the UK Electrical Forum area at ElectriciansForums.net
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
