Guest viewing limit reached
if your unsure get your freind to help you, i personaly would of done it on my own after heavy research.
only because i like the satisfaction of knowing that i did it and could do it again and charge people but also you can't learn without making mistakes and mistakes are what freinds and family are for when they want something done for very little.
defo wirless is way to go pay for a half decent one yale are fine its worth it yep you can bypass the moggi have only had signal problems once and that was a huge hall with walls 5-6ft in places should not have a problem mate
wireless i s easier, quicker. no probs with wireless signal in the average house. try risco.co.uk. comlete kit, including 6 detectors ( order pet tolerant PIRs) £209+vat. that's everything bar cable which you need to hard wire the bell and the keypad.
Your best bet is to buy telectrix's dog - the only downside is having to clean up the mess after they have tried to break in :D
she's available for hire. £7 an hour and she gets to keep what she catches.
Thanks for the reminder of my age oldtimer, I used to fit Logic 4's
I used to fit KJ Bentleys before plastic panels were even thought of. Full Guard/Part Guard on a key. Top of the range was 5 zones. Panel was nearly as big as a 3Φ Dis. Board.CC wired doors covered with plywood. All wiring double pole, Tube & batten frames over windows and skylights, none of this in and out in a day.
And what about the Bentley F130 (first ever NVM panel) or the A&G Micro three delux even or Dimpomat or the crappy Envoy aye these were the days
PS still got the manuals if you need them
only remember the F130 vaguely. from the Bentleys we went to Munford and White. they later became Tunstall.
i=p/u
Northern Ireland
United Kingdom
burglar alarm!!!!
Security Alarms, Door Entry and CCTV (Public)
i=p/u,
Burnt Fingers,
