Butt connectors | Page 2 | on ElectriciansForums
Discuss Butt connectors in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
i have put wagos into a metal enclosure mounted on a wooden plate clipped externally to blank gromit or compression gland. this meets all regulations and provides a maintenance free joint that can be accessed under a floor at a later date if needed. just make sure you identify all cables. future proofing the addition of works.
Reply to Butt connectors in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
They are excellent, I have used them a few times for consumer unit relocations! They can get a bit tight with cables if you're using all the...
Thanks for that information I'll have a look at.
