Buying flat, Consumer Unit replaced but no notification | on ElectriciansForums
Discuss Buying flat, Consumer Unit replaced but no notification in the DIY Electrical Advice area at ElectriciansForums.net
England
Hi All,
I am in the middle of purchasing a small 1 bed flat in England, and have been sent a Domestic Electrical Installation Certificate by the seller (horizontal red form with 6 pages). The certificate states work was done 4 years ago including new sockets, downlights and a 'new consumer unit'. The tick box next to 'replacement of a consumer unit' is N/A. I believe the main consumer unit was replaced as it looks quite new and has a 're-test in 5 years' sticker with the certificate's date. I can't imagine there is another consumer unit in the property as it's quite small and there is no outbuilding/garage. There is no notification with NICEIC.
I was expecting for this work to be notifiable, should the electrician have ticked yes to 'new consumer unit'? I'm concerned this may cause issues when I resell the property if this work was not notified correctly, and am considering getting an indemnity policy to cover any issues reselling.
Many thanks!
TL;DR
New consumer unit buy no notification
Sensible approach.
When it comes to resell, you could get an indemnity policy, or get an EICR done. This will give an overall view of the electrics, in terms of safety…. including the consumer unit.
Reply to Buying flat, Consumer Unit replaced but no notification in the DIY Electrical Advice area at ElectriciansForums.net
Yes that does appear to be the case. I may get an electrician to fit the correct glands. Thank you.
It won't be notifiable though as its not a new circuit, if you change the the tails from 16mm to 25mm is that notifiable? No, if you add an...
