My alarm panel is going into alarm when entering the premises | on ElectriciansForums
Discuss My alarm panel is going into alarm when entering the premises in the The Welcome Forum area at ElectriciansForums.net
Daciaduster24
hi i have a Honeywell Galaxy 2-20-V15 version 1.5 security system and was working fine but the engineers code was lost so as i needed to add more circuits,i defaulted the panel back to factory settings and now have an enginers code . I have reprogrammed the panel and included new circuits and everything appeared to be fine, but the problem is the system is setting fine but on unsetting it immediatly goes into alarm
This is curcuit 1001 programmed ,final and timed each way 30 seconds/entry and exit
I cannot find anything in the programming to explain the problem but the log indicates code - ENT T/0 can any one advise please ?
regards Paul
regards Paul
I’m not familiar with the panel but it seems to be that the entry is programmed to 0 time hence the alarm straight away.
Most alarms that i have seen just have an entry exit time and not have separate ones.
Do you get a beeping when you set the alarm for exit.
yes the alarm is programmed 30 seconds entry and 30 seconds exit yes it does beep and sets fine
Is there a detector on another zone / circuit that also is covering the exit route?
Maybe try eliminating each detector 1 at a time then trying the final exit each time.
Reply to My alarm panel is going into alarm when entering the premises in the The Welcome Forum area at ElectriciansForums.net
Thanks. I do a lot more for the site than just change a few alarm batterys. EICRs, PAT, numerous little jobs. Never away from the place.
